point expression with spare input
   3070   3   1
I'm confused. I wanted to use a spare input with the point expression. Which is shown in the docs here:point() [www.sidefx.com]
it gives two examples both require three parameters
<type> point(<geometry>geometry, string attribute_name, int pointnumber)
<type>[] point(<geometry>geometry, string attribute_name, int pointnumber)
so I tried this:
 point(-1,"dist", 0)
doesn't work...
turns out I needed this:
point(-1, 1, "dist", 0)
What? I don't see this anywhere in the docs. Is it there? why not in the point expression card?
thanks
Nathan Apffel
point(-1,"dist", 0)
This is correct.
What you referenced is point() VEX function
But sounds like you are dealing with parameter expressions and therefore using point() [www.sidefx.com] hscript expression function which has slightly different syntax as you noticed
Edited by tamte - July 31, 2021 03:31:09
FX Supervisor
Method Studios, NY
Thanks,tamte. hscript expression functions (which are listed as expression functions in the docs point expression [www.sidefx.com]) are used for parameter fields, not vex functions. This has been a source of confusion for me. thanks for the response.
