hi everyone
i am looking for a solution to a pdg question i have.
after generating many different version of an asset, is there a way to remove random work items at the end of the tree before they are being rendered in a rop node?
//EDIT//
i just noticed a different post that filters the amount of workitems and deletes an amount, via a python processor. (https://www.sidefx.com/forum/topic/84535/)
being a python noob, how would this be rewritten into keeping an amount of workitems?
import random
choices = random.sample(range(0, len(upstream_items)), k=200)
for index, upstream_item in enumerate(upstream_items):
if index not in choices:
item_holder.addWorkItem(parent=upstream_item)
random work item ignore
2118 7 1- doodlemaker
- 16 posts
- tamte
- 8599 posts
- doodlemaker
- 16 posts
- doodlemaker
- 16 posts
tamte
you can use the same code as in the attached post
tweak K=200 to how many you want to keep, like k=10, etc
and changetoif index not in choices:if index in choices:
i have a follow up question, i batched 500 workitems and send them to deadline to be rendered with an OPENGL rop.
they are 500 randomly chosen of 960 total variations.
during the render my pc crashed, about 260 were rendered.
now when restarting, the index of the randomly chosen list has changed, 500 new variations are chosen.
is there a way to 'bake' a list of random items, so houdini, when restarting, can use those and find the previous rendered results on disk?
=edit=
after the crash, the connection to deadline also appears to be gone. the unfinished, queued items cannot continue.
can one keep this connection alive after restarting houdini?
Edited by doodlemaker - June 14, 2022 05:48:25
- doodlemaker
- 16 posts
[quote=Ä
Note for future references, there is an option to save the task graph on the top network node.
This also saves the index of the tree, including the randomly generated variations. So in case there is a crash, loading up the task graph file will get the same “build” as before and the cook will find the files on disk
- tamte
- 8599 posts
doodlemakerthat's how random in python works by default, every time it generates different set of sample values, which is obviously not good
to get stable sample set every time it cooks you need to initialize the seed for the random generator
import random k = 50 k = min(k, len(upstream_items)) # limit to n items to avoid overflow random.seed(10) # you can change 10 to different number to ger different set of random numbers choices = random.sample(range(0, len(upstream_items)), k) for index, upstream_item in enumerate(upstream_items): if index in choices: item_holder.addWorkItem(parent=upstream_item)
Edited by tamte - June 15, 2022 20:17:00
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- doodlemaker
- 16 posts
tamtedoodlemakerthat's how random in python works by default, every time it generates different set of sample values, which is obviously not good
to get stable sample set every time it cooks you need to initialize the seed for the random generatorimport random k = 50 k = min(k, len(upstream_items)) # limit to n items to avoid overflow random.seed(10) # you can change 10 to different number to ger different set of random numbers choices = random.sample(range(0, len(upstream_items)), k) for index, upstream_item in enumerate(upstream_items): if index in choices: item_holder.addWorkItem(parent=upstream_item)
Thanks Tomas!
That solution is much more practical!
- cybernetix
- 22 posts
