Hi guys. So I ran into the typical "follow a tutorial and hit a brick wall".
I just don't get the Geometry input from Houdini in UE5 like the tutorial does.
Anyone knows what's causing this?
Tutorial Im following
https://www.youtube.com/watch?v=DszHOKxTkyU&list=PLXNFA1EysfYl_JM9Dgs0gpo394YhLEeZ2&index=4 [www.youtube.com]
Super greatful for any advice
Geometry Input Missing UE5
1243 1 0- kodapojken
- 6 posts
- dpernuit
- 535 posts
Likely, your HDA simply has no inputs
https://www.sidefx.com/docs/unreal/_inputs.html#InputNode [www.sidefx.com]
either add inputs in the type properties if it's a SOP HDA, or expose an object merge Object parameter on your HDA.
The other possible issue, could be licensing, as the inputs/parameters won't show up in Unreal if the plugin can't get a license.
(and as a reminder, Houdini Engine plugins won't work with Houdini Apprentice / .hdanc files)
Likely, unreal's log should display an error message, or selecting an HDA should indicate in the details panel if the session has any issue.
