How to visualise VDB files properly
   Views 9842   Replies 28   Subscribers 2
I am a programmer and I need to validate some VDB file I created (I am not an artist and not really familiar with houdini)
I imported the VDB file and then used the VDB Visualize Tree node to see my voxels, but I would like to also be able to read the metadata of the grids and display each group into a different color. Is there a way to do this ?
Vincent
Edited by guesdon.vincent - July 22, 2022 10:07:08
I tried to set the Cd attribute on each group but "VDB Visualize Tree" seems to override or ignore it
If you open the geo spreadsheet (RMB on node -> Spreadsheet), you can view the intrinsic attributes that are available. Make sure to be in primitive mode and toggle the intrinsics that you want.
that's great, thanks, now I can read my metadata at least
and to display my colors as voxels boxes ? I'd like to see each voxels boxes as the proper color (imagine a minecraft world exported into a VDB file and you want to display properly the color of each voxel, they are already grouped properly per material)
see here an example in the game and the VDB created from it (Frustrum extraction)
at the moment my prototype just put a random color in the Cd attribute, but after that I can't display it in Houdini
Edited by guesdon.vincent - July 25, 2022 14:25:58
still trying, cannot figure out why "VDB Visualise Tree" remove all my colors, I can see the colors are correct when looking at the cloud point but as soon as I try to display the voxels boxes houdini remove all the colors
ok, I am done trying to make VDB visualize tree to work. Can somebody explain to me how to remake something equivalent using maybe box and copy to point ?
I tried to make one but it doesn't display anything
this diagram reproduce exactly the same result as VDB visualize Tree but unfortunately the Cd attribute is lost in the process, is there a way to apply the Cd attribute to each boxes from the metsadata available for each group ?
closing this subject, going to work on other thing since this is completely blocked for now
Edited by guesdon.vincent - July 25, 2022 14:34:21
I had a little time today to come back to this.
So if I understand correctly my main issue is that the node PointFromVolume is loosing all the Cd attributes from my VDB primitives. So I have my colors fine when rendering the VDB node but after that everything become grey.
I tried to use the AttributeWrangle node to reapply my Cd attribute from my primitive to my points and the result is better (I can see my voxels having different colors) but not that great (clearly not the proper colors from the original VDB.
here the VEX expression I used in the Attribute Wrangle node
int prims[] = primfind(1, @P, @P);
v@Cd = set(0,0,0);
foreach ( int prim; prims )
vector ocd = prim(1, "Cd", prim);
v@Cd = ocd;
break;
and here my graph
Any idea if there is a better way of doing it ?
Edited by guesdon.vincent - Aug. 4, 2022 15:04:25
Isn't this working out of the box?
Not sure I understood your original question, but here's a sample showing how to vis various volume attributes with the vdb tree sop.
vdb_viz_cd_as_blocks.hip (301.3 KB)
unfortunately it doesn't work, as soon as I try to render it the color is removed and everything become grey.
on my data I have 16 primitive each of it containing voxels, each primitive represents a specific color with the attribute Cd in the primitive attributes. (I don't have any texture for the moment)
when displaying the VDB only, I can see the color of the primitives are used for the color, but has soon as I try to get a voxel effect (displaying a 0.1 meter box on each point) all the colors are removed (I tried my own graph and VDB vizualize tree both do the same things, when you display the boxes the color are removed
the closest I got from a result was with the VEX expression trying to recover the Cd attribute of the primitive for each point using the attribute Wrangle node (but even this doesn't work very well)
Edited by guesdon.vincent - Aug. 5, 2022 09:50:53
In my setup I found the colours went strange when I added extra volumes. To get around this I cast whatever attributes I needed using a wrangle to @Cd, and then on the vis tree node, forced it to only read the @Cd volume.
mestela
Sorry I don't understand how to do that, as I mentionned on the first message I am not an artist, I am only a programmer trying to vizualize that the things my code serialized with openvdb is correctly built
I opened houdini for the first time around two weeks ago and used it maybe 4-5 days in my life so I know almost nothing about it
and unfortunately , even so I would love to, I don't have the time to read / watch tutorial or do formation on it (I have my own work to do )
here three different view of my VDB, one is the original file (you can see the colors) second is VDB vizualize tree as points, third is by copying the box on each point
Edited by guesdon.vincent - Aug. 9, 2022 10:30:12
guesdon.vincent
Its in the example hip in my earlier post.
ok I'll look at it again to try to see why I couldn't make it works last friday but it seems to me that the output of VDB from polygon in your example is different from what I have.
Edited by guesdon.vincent - Aug. 8, 2022 09:03:00
sorry but I tried again and still the same issue impossible to get the Cd attribute from my primitive to my points
maybe I am not describing it correctly, but I am not sure how to explain it, I have Cd color in my primitives attributes and these color are lost when using VDB vizualize Tree
Edited by guesdon.vincent - Aug. 8, 2022 09:58:07
Can you post a simple hip file with a reduced dataset? You'd probably get a fix from someone pretty quickly with an example file.
antc
I am thinking about it, I have to check what exactly I can share on a public forum. I might have to generate a fake VDB without specific data
Edited by guesdon.vincent - Aug. 8, 2022 12:19:40
In the meantime the only thing I can suggest is perhaps post what the info window looks like for your vdb geometry. You can get that by middle clicking on the node itself. It'll detail the available grids which might give a clue. If there's a vec3 grid present called Cd I'd expect matts example file to work but who knows.
