hey I'm trying to figure this thing out once and for all
how would I match a real-world camera to Houdini? the focal length is easy
the aperture is what I understand is the horizontal sensor size /2... or something
if that's so how would I get the vertical?
for all-purpose, Alexa35 is 27.99 x 19.22 sensor size, the sensor aspect ratio of 16:11,
how do I match that?
thank you in advance.
match real camera in houdini and solaris
1405 2 1- sachiman
- 38 posts
- jsmack
- 7837 posts
Unless you're doing anamorphic rendering, you can ignore the sensor height, as it will be based on the resolution aspect ratio and width. For houdini camera objects (not solaris) there is no sensor height parameter, just resolution and width. For solaris, the sensor height can be defined manually, but is based on the aspect ratio and width by default.
Edited by jsmack - Aug. 8, 2022 18:45:35
- sachiman
- 38 posts
