Houdini engine can't detect the installation of HEU in unity
   1607   2   0
Hi i can't seem to solve this issue so i would appreciate some help.
I have houdini version 19.5.368 and same version of unity plugin installed.
my system info are these
Enhedsnavn DESKTOP-N6LVBDK
Processor 11th Gen Intel(R) Core(TM) i7-1185G7 @ 3.00GHz 3.00 GHz
Installeret RAM 16,0 GB (15,7 GB kan bruges)
Enheds-id FF03F3E8-B519-4C64-9A80-704391A88946
Produkt-id 00325-96731-99201-AAOEM
Systemtype 64-bit operativsystem, x64-baseret processor
Pen og touch Understøttelse af pen og touch med 10 touchpunkter
Udgave Windows 11 Home
Version 21H2
Installeret d. ‎23-‎12-‎2021
Operativsystemets build 22000.978
Serienummer PF250221
Visning Microsoft-pakke med funktionsoplevelse 1000.22000.978.0
I am able to create HDA's in houdini, but it seems like houdini doesn't take a path on my oonedrive as a valid path.
when i drag them into viewport this error message happens
When i try to run sessionsync
I get the win32error: file not found
Does anyone know how to fix this?
Seems like you have the H19.5.303 plugin installed in Houdini, but have Houdini 19.5.368 installed.
The plugin is looking for 19.5.303 but cant find it.
The easiest solution would be to reinstall/reimport the plugin using the unitypackage in your H19.5.368's engine/unity folder.
It worked. Thank you so much, i have been starring myself blind, missing this detail during the trouble shooting.:o
