Finding a 'best fit' plane through a set of 3D points
   Views 3639   Replies 12   Subscribers 4
Does anyone have a solution to finding a 'best fit' plane through a set of 3D points?
I do realise that 'best fit' is a rather ill defined requirement, but it's not critical for the project I'm thinking of.
Hey Mike_A,
might not work in any case, but could give you a starting point.
Edited by CYTE - Nov. 18, 2022 09:38:39
Bounding Rectangle.hip (109.7 KB)
https://www.orbolt.com/asset/animatrix::bestFitPlane::1.00
Here is one way using PCA (Principal Component Analysis):
Attrib Promote (P) = Point -> Detail | Average
Compute sum (Point Wrangle):
vector centroid = detail ( 0, "centroid" );
vector p = v@P - centroid;
setdetailattrib ( geoself ( ), "sumxx", p.x * p.x, "add" );
setdetailattrib ( geoself ( ), "sumxy", p.x * p.y, "add" );
setdetailattrib ( geoself ( ), "sumxz", p.x * p.z, "add" );
setdetailattrib ( geoself ( ), "sumyy", p.y * p.y, "add" );
setdetailattrib ( geoself ( ), "sumyz", p.y * p.z, "add" );
setdetailattrib ( geoself ( ), "sumzz", p.z * p.z, "add" );
Compute PCA (Detail Wrangle):
matrix3 m = set ( @opinput1_sumxx, @opinput1_sumxy, @opinput1_sumxz, @opinput1_sumxy, @opinput1_sumyy, @opinput1_sumyz, @opinput1_sumxz, @opinput1_sumyz, @opinput1_sumzz );
matrix3 u = 0;
vector s = 0;
matrix3 v = 0;
svddecomp ( m, u, s, v );
v = transpose ( v );
vector x = set ( v.xx, v.xy, v.xz );
vector y = set ( v.yx, v.yy, v.yz );
vector z = set ( v.zx, v.zy, v.zz );
vector centroid = v@opinput1_centroid;
int pt = addpoint ( geoself ( ), centroid );
setpointattrib ( geoself ( ), "x", pt, x );
setpointattrib ( geoself ( ), "y", pt, y );
setpointattrib ( geoself ( ), "z", pt, z );
setpointattrib ( geoself ( ), "N", pt, z );
Thank you all - much appreciated!
That would be really good to have as a HDA - but unfortunately it doesn't seem to work in 19.5 - unless I'm missing something.
If there is a possibility of an updated version I would be very appreciative, but do understand that delivering such is work...
Mike_A
This is a very old OTL. Many things changed in VEX since then.
The above method I posted is superior. So you can turn that into an HDA if you wanted.
Thanks Animatrix - that's fine and understood. The PCA code you kindly offered above is a great solution and much appreciated I'll make a HDA from that as you suggest.
Edited by Mike_A - Nov. 19, 2022 12:00:42
Hey animatrix,
I'm trying your example with H 19.5.640 But it is not working. Has anything changed since you posted the PCA solution?
An update would be highly appreciated!
Cheers
CYTE
Yes it still works. Are you sure you set grid geometry to XY Plane orientation before copying?
I've just published an example file with animatrix' code here:
https://procegen.konstantinmagnus.de/fitting-planes-to-point-clouds [procegen.konstantinmagnus.de]
I have probably missed something with svddecomp , everytime i struggle with one direction which looks off to me..
So if i take your version, i get the reduction red plane, doesn't look that correct not?
I could improve the result with some "prefiltering", which give me the blue plane , way better already...
Have you also noticed or is it me only?
Vincent Thomas   (VFX and Art since 1998)
Senior Env and Lighting  artist & Houdini generalist & Creative Concepts
http://fr.linkedin.com/in/vincentthomas [fr.linkedin.com]
ah thank you Konstantin and animatrix, I missed the part that the detail attribute needs to be named centroid!
edit: ah bummer I thought it would respect the nonuniform scale of the target, too....
Cheers
CYTE
Edited by CYTE - Oct. 27, 2023 07:26:31
