How to set prims at certain path in Awrangle.
   2423   7   4
Hello I`m trying to set all primitives at a certain path with this code but it doesn't work.
Anyone know what might work ?
Primitives:
`lopinputprim('.', 0)`
VEX:
if(usd_kind(0, @primpath) == "component")
@primpath = "/ASSET/geo/render" +@primpath;
primitives:
%type:Mesh
VEX:
@primpath = "/ASSET/geo/render/test";
printf(@primpath);
I`ve also tried with python but apparently the get children function doesn`t exist ?
import pxr
import hou
stage = hou.pwd().editableStage()
root_prim = stage.GetPrimAtPath("/")
# Loop through all child prims under the root prim
for child_prim in root_prim.getChildren():
    # Check if the child prim is a component and perform action
    if child_prim.getTypeName() == "Xform" and child_prim.getPurpose() == "component":
        print(child_prim.GetName())
Edited by nicolaas.tanghe - March 16, 2023 17:04:50
Before answering the detailed questions here, I want to take a step back and ask what you're trying to achieve. I just want to make sure we give you useful answers/information.
Example:
my scene graph looks like this.
|---example
| |-geo
|---geo
| |-spaceship
|---blablabla
| |-blablabla
Im trying to move geo/* to example/geo/ with keeping the geo configured the way it is configured at example/geo
in a wrangle or if not possible in a python scipt.
Edited by nicolaas.tanghe - March 19, 2023 15:49:51
Ah, I see. Shuffling USD prims around like that isn't really possible this way. The best we have to offer at present are the Stage Manager and the Graft Branches LOPs.
Oh that`s to bad,
Would be a great addition i think.
I`ll use the graft branch then THX for the time and effort.
nicolaas.tanghe
Yes, restructuring the scenegraph is a commonly requested feature. It's definitely on our mind (and I believe on Pixar's as well)
There is also the Restructure Scene Graph LOP [www.sidefx.com] that can do some measure of restructuring (reparenting, renaming, removing). It requires sub-layer flattening of the inputs, but is another option to keep in mind for these sorts of cases.
I'm o.d.d.
Not sure if I'm asking the same question as above, but I'm trying to use the restructure scene graph node to tidy up an older usd stage that I have without having to go back to the original graph and re-author everything. Unfortunately I'm running into an issue when reparenting some instancable prims and their respective prototype prim. When I reparent the instances, they retain their reference path, but when I move the prototype as expected this breaks the instances. Is there any way to change that path with vex after reparenting or is it a python thing?
