I've tried to update some dataset through a json file but noticed when the houdini plugin cooks the actor, it doesn't refresh unless I rebuild the actor. Does anybody know why it's doing this?
Thank you,
Gary
Plugin cook the same data unless rebuild
1024 1 0- gng
- 4 posts
- dpernuit
- 534 posts
That's actually expected as the plugin doesn't check for changes on asset in the content browser.
(the issue would be similar for Static Meshes in a geometry input).
This will be addressed soon by a change that will add allow you to only refresh a single input.
(which at least, prevents resending all the other input's data)
