Hi! Following goldleaf's advices in the other thread I used the XPU Pyro Preview material in the Stage's material library.
But from what I understood I must first setup a Pyro Bake Volume in the geometry level. So that's what I did. I followed some Youtube tutorials to set this up.
But unfortunately all my colors are not transmitted from the Pyro Bake Volume to the XPU Pyro Preview Shader.
The Smoke, bound to density, is all white, instead of orange.
The Scatter, bound to scatter, is all white, instead of orange.
Fire and secondary fire, both bound to flame, are more close to their Pyro Bake Volume origins but still do not look like what I set up.
Please check the pic.
David
Pyro Bake Volume to XPU Pyro Preview Shader : no colors
1550 4 1- Grendizer
- 375 posts
- Enivob
- 2544 posts
- Grendizer
- 375 posts
Hello Enivob
Well I got this triple nodes setup when I went into pyrobakevolume1 > quick setup drop down menu > create material.
I don't understand why Houdini puts a Pyro Shader and a Combined Pyro shader, I think only the XPU Pyro Preview should be enough, shouldn't it?
Here, in the material library of the stage context, I re-established the material flags are they were set when I used this menu.
In the pyrobakevolume1 node, in the "assign material" option, I entered the path to this Combined_Pyro_Shaders node.
But the result is the same. Check the pic, thanks.
NOTE: I forgot to mention that I'm trying to render with Karma XPU.
David
David
Edited by Grendizer - April 26, 2023 13:33:18
Houdini gamboler
- Grendizer
- 375 posts
- Grendizer
- 375 posts
