Example of using stroke meta data ?
   351   0   0
I'm interested in building a stroke tool that associates the frame number at which a stroke was drawn with the primitive of the stroke. It seems like stroke meta data maybe a good way to handle this, but following the docs it doesn't seem to work.
Does anyone have an example of setting custom data per stroke, and doing something with it after the stroke node inside the hda?
I have tried making an hda with just a stroke node inside, setting the hda Node Default State to stroke, dragging the Number of Strokes parameter from the parameters panel on the stroke node inside the hda to the Edit Operator Type Properties Parameters panel of the hda. Then adding a new parameter on the hda properties called something like stroke#_frame or stroke_frame#. According to the docs the Meta Data parameter on the stroke geometry node:
"Stores the values of all parameters whose names start with stroke_ from the top level node. These are copied into correspondingly named primitive attributes."
But the Meta Data always seem to contain just a list like
[ 0 ]
I can't figure out what I am doing wrong?
Edited by cruiserandmax - Oct. 23, 2023 18:16:34
