Im new to Houdini, and am exploring hair simulation. More specifically, I'm looking into simulating curves/guides brought in from outside sources. In this case im bringing in curves/guides and animated geo as alembic. I'm able to bring it in using the guide groom and guide deform object nodes. While I have used and explored just adding a guide sim node after, I've wanted to look into doing a sim building a vellum network. I am currently stuck where I run the vellum solver and curves/guides just fall off. I know i need to add a pin to target vellum constraint in-between the hair constraint and the vellum solver. However I'm having trouble finding and creating a group that have the base points of the curves/guides that are attached to the animated geo. I've heard of a roots group, but when i put it into the group section on the pin to target constraint nothing happens and the vellum solver just shows a static non animating pose. This let me to believe that the roots group does not exist and that i have to create the group, but i'm not sure how to do that. Any help would be greatly appreciated.
Help! Finding and creating a group for the roots of curves
771 2 0- SerenityFirefly
- 3 posts
- sepu
- 436 posts
You need to pin your points on the hair vellum constraint and for that you can use the group expression sop and it has as a snippet code for this "first point of primitive" `vertexprimindex(0, @vtxnum)==0` also make sure you have match animation and depending on your needs you can play with the pin type orient pin type
- SerenityFirefly
- 3 posts
