H20 - feathers - easy way to make the shaft stiff?
   1635   6   2
I am simulating a single feather in vellum.
The entire workflow works fine.
Only the shaft is even more limp than the barbs when simulating, no matter how high
I set the stiffnesses of stretch and bend.
Any ideas on how to make the shaft stiff in a vellum sim?
What am I missing?
Thanks so much!
I know vellum doesn't like too many divisions or stiffness becomes impossible to enforce. The only way to increase stiffness is to increase iterations or reduce subdivisions.
Thanks! I know that.
I was specifically referring to the feather workflow.
And treating the barbs differently than the shaft.
Which just makes sense.
You probably have something like 500+ points on the shaft curve if you're trying to simulate the full feather. There's not much of a way around that because you need the barbs connected.
But you will always get a floppy curve with that many points.
As a workaround, you could copy the shaft curve and resample that to 8-20 points, set up constraints on that and also constrain it to the real shaft curve. This could stabilize the whole feather and require fewer constraint iterations. I haven't tested this though. Make sure collisions between those overlapping curves aren't computed.
Kai Stavginski
Senior Technical Director
KaiStavginski
Hello Kai!
Thanks for your quick answer.
That sounds like something I could do.
But you get the idea?
Maybe something for an update?
At least a shaft group output, maybe on the feather interpolate?
Best regards!
sim a curve with less and then you can wiredeform the one with the feather.
pelos
I'm sorry, I didn't understand
that.
Would be happy if you could be more specific.
Thanks so much!
