curve sop h20
   631   2   0
Hey there, I have a weird crack in h20 driving me crazy.
Whenever I lay down a curve sop, my defaults are polygon and not bezier; the dropdown menu is highlighted, meaning it's not the default.
I've tried to factory default it, and the specific sop goes back to bezier default, but it keeps coming back, and since you can't change the drawn curve to bezier after it's drawn, it drives me up the wall.
Instead of selecting a curve sop which is intentionally set for polygon, just select Curve Bezier sop to start with as it defaults to Bezier as the name implies.
Even if you did start with a curve sop set to polygon, just change it before using it.
Thanks, I thought the curve default is the bezier since it gives you both straight, bezier, and features like corner rounding that you cannot find on a polygon, and once you start sketching, you cannot change it, it kind of bums me out (I've sketch quite a lot o well
