I want to desaturate an image form colour to black and white within Houdini. I understand this can be done in a COP2 Network. WHich node would I use to desaturate and which parameter do I adjust?
The image is an HDRI to be used in an Environment Light, so I assume this is the method to use.
How to desaturate image in Houdini (COP2 Network)?
806 7 1- litote
- 229 posts
- mestela
- 1746 posts
- animatrix_
- 4531 posts
You can use the HSV COP:
mestela beat me to it dammit!
Edited by animatrix_ - Jan. 25, 2024 01:43:51
- litote
- 229 posts
- animatrix_
- 4531 posts
litote
Thanks, how do you show the image in the viewport? Composite View presumably?
OK Got it to work. Thanks.
It shows a desaturated image in the Composite View OK.
If you cook the COP network node, it should show the result in the viewport.
- litote
- 229 posts
- animatrix_
- 4531 posts
litote
How do I stop the COP2 Network image showing in the Scene View? Presumably I have to put it inside a Geometry node and deactivate its display flag?
You can display another node like a null node.
- litote
- 229 posts
