[SOLVED] How to change UV Edit pivot?
   470   3   1
Has anybody found a way to change pivot location in the UV Edit SOP? "Insert" key, doesn't work, orientation picking only translates the selection, and modification of px, py and pz parameter doesn't have any effect whatsoever.
Edited by ajz3d - Feb. 25, 2024 16:29:31
For the time being, my workaround is to edit UVs in world space as Pand move Pdata to uvafterward. Somewhat ridiculous, but at least I can manipulate the pivot of each selected UV island.
I'll send an RFE regarding this issue.
Edited by ajz3d - Feb. 25, 2024 16:29:13
Just like in the 3D viewport, pressing the apostrophe key will toggle pivot translate mode. Move it where you want then press apostrophe again.
You've just made my day.
Thanks.
