Documentation
"Render all frames in a background process. Default is off. This allows continued interaction with Houdini while the render process runs.
To render multiple frames, the render process renders an image then advances the time on the scene and renders the next image (just like how the Solaris viewport plays back animation). If there is a lot of data shared between frames, this can render significantly faster compared to rendering a single frame per process."
When checked it renders out my frame sequence in 4 seconds per frame, unchecked it's around 20 seconds per frame, so why is this unchecked by default? Any drawbacks or situations where using this is a bad idea?
