Hi all,
I am rendering ROPs with Arnold on multiple GPUs (+possibly I could use also CPU). Is there a way to render jobs simultaneously on separate cards? If I chain multiple render nodes I have options to render Node by node or frame by frame but with this scenario only 1 card is used at a time.
I could specify frame range for card 1 and another frame range for card 2. However, 1 GPU is slower than the other one so in super ideal scenario I would use some TOPs network where render for each card checks whether the output file has been already created and continues rendering another frame until the whole frame range is finished with both cards.
What is the best way to approach this?
Many thanks for any suggestion
Render multiple ROPs simultaneously
258 0 1- gunjack
- 5 posts
