Hi ,
I'm doing an animation with vellum where points of hairs are being deleted when entering a bounding obj (got this working)
But I would like to add a condition where only the first and last point can be deleted, so no points in the middle can be deleted first.
I thought of doing that by grouping the first and last point, but I can't get it to work for each hair.
Any help or ways to do that would be very helpful , thanks
Basically having the red points in a group , that will be deleted if they go inside a bounding box, and if they get deleted the green points become the first or last point, inside a dop network.
Deleting first and last point over for each primitive
275 3 0- nledren
- 1 posts
- BabaJ
- 2041 posts
You can isolate/group/set attributes for the first and last points of the primitive by
using the primpoints() function.
It returns an array of point numbers that belong that prim, in the same order as they are on the primitive.
So you can select by index the first element and last element of the arrays.
Edited by BabaJ - April 18, 2024 12:03:48
- rafaels
- 696 posts
Use the group expression SOP on points and pick the "point valence" preset from the dropdown.
A value of 1 should be enough to pick up the extremities of each primitive.
Toronto - ON
- animatrix_
- 4518 posts
Here is one way:
Here is one way:
if ( neighbourcount ( 0, @ptnum ) == 1 ) i@group_endpts = 1;
youtube.com/@pragmaticvfx | patreon.com/animatrix | animatrix2k7.gumroad.com
