Pyro Bake Volume - Break Material References?
120 0 1- litote
- 229 posts
In the Pyro Bake Volume node there is an option under Quick Setups button menu at top to select Break Material References. This disconnects the parameters between the Pyro Shader node and the Pyro Bske Volume. Is there a way to reconnect the parameters in one step? I don't see an obvious option in this menu.
