I not able to save the recepie and load it back if I try to save a recepie which contains `karma lens material` LOP,
However if I try to save a new `edit material properties` with defaults it works fine.
Is it just me or everone is having trouble with this?
RECEPIE - Unable to store a recepie with `karmalensmaterial`
708 3 2- Mohanpugaz
- 146 posts
- goldleaf
- 4193 posts
- Mohanpugaz
- 146 posts
Thanks for reply.
Yeah I can understand that it is just an Edit material Properties LOP with some predefined parameters.
But I just want to save it along with other Nodes. (Kind of a turn table template which includes this node with lens parameters).
I don't really want to host the recepie (im guessing the anchor node is what you mean here)
using that particular node. But even if I host it on any other node it still doesn't work.
Basically in short Edit material Properties LOP which has the lens Properties in it is not working when trying to save it in a recepie.
Hope that was clear. Sorry if I'm adding more confusion.
Mohan Pugaz
movfx
movfx
- alex_sidefx
- 5 posts
