Copernicus: White mono islands to id?
1678 5 2-
- ajz3d
- 654 posts
- PHENOMDESIGN
- 172 posts
https://www.sidefx.com/docs/houdini/nodes/cop/segmentbyconnectivity.html [www.sidefx.com]
This operation breaks the incoming layer into connected components according to a rule.
Parameters
Signature
The layer type that the source accepts.
See Signatures for more information.
Connectivity
This rule determines if pixels are connected or not.
Below Threshold
All pixels below the threshold are connected.
Above Threshold
All pixels above the threshold are connected.
At Threshold
Pixels are connected to their neighbours if they are on the same side of the threshold.
At Levels
Pixels are connected if they are in the same “band” of values. Each band is of size Threshold.
Threshold
The threshold for connectivity. For levels, this is the width of a band of connectivity.
Offset
A global offset for the At Levels mode to adjust where the bands split.
Inputs
source
A Mono or ID layer to detect connectivity in.
Outputs
id
An ID layer with a unique integer greater than or equal to zero for each connected region. Regions that do not match the connectivity region get an ID of -1.
alpha
A Mono layer which is 1 if the pixel met the connectivity rule, zero otherwise.
Parameters
Signature
Connectivity
Below Threshold
Above Threshold
At Threshold
At Levels
Threshold
Offset
Inputs
source
Outputs
id
alpha
PHENOM(enological) DESIGN;
Experimental phenomenology (study of experience) is a category of philosophy evidencing intentional variations of subjective human experiencing where both the independent and dependent variable are phenomenological. Lundh 2020
- ajz3d
- 654 posts
- Mike_A
- 393 posts
- ajz3d
- 654 posts
Yeah, it could be aliased to this name at least. Last week I used an equivalent of shape splatter node from Substance Designer. But today I forgot what it was called. Perhaps it was Stamp Points? I guess in time, we'll get used to those node names. I might complain about this and that, but I'm very thankful that SideFX finally decided to jump into procedural texturing department to completely dislodge Adobe from their monopoly in this field.
Once sculpting and painting tools improve (and their performance), I might even ditch Substance Painter altogether. I was considering purchasing InstaMAT once its native GNU/Linux version is finally released, but with Copernicus under my disposal, I see no need to do so anymore.
Edited by ajz3d - Aug. 1, 2024 19:11:43
- PHENOMDESIGN
- 172 posts
I wonder about this too. Icons are more universal than text. So I think that the icons, well Icons have been proven to be good for memorization and associations, but I think that they help and it is a big part that APEX Graphs are missing. The nodes with Icons are actually the single distinguishing feature from other node software. But then there is also the semantics of meaning etc. but specifically, associating a node with an Icon as opposed to a long feature name is a cognitive affordance.
So the Icon on this references a mesh segmentation and is non isomorphic (does not directly relate to the form of function). I maybe bias but this Colorful Camo kinda looks like a more representative iconography for this.
I am working on semantic embeddings for search and cognitive load lessening. I think that having a "discussion" with the documentation and to question semantically the software about key features is approachable now. This way you can have creative intent that does not have artifacts of the "technology" medium.
I see things moving more inline with Human Machine Teaming Interfaces for Intentional Creative Computing. Machine Programming has some good ideas about this too:
Edited by PHENOMDESIGN - Aug. 1, 2024 20:15:41
