Set Subd in Component Geometry node
   686   5   3
Hello All
Usually I use Sopcreate for my workflow, but this time, I try to use the Component builder and I have a problem :
I'm used to create an "attribute create" node to specify which object should be subdivide and wich is not.
Then, in lop context, I just check "USD Custom Attributes" and type "subdivisionScheme" and everything works fine (like in my two screencapture bellow).
But, if I use the component builder, there is no "USD Custom Attributes"...
When I leave my mouse on top of "Treat Polygons as Subdivision Surfaces" it says "Any polygon meshes not already tagged as subdivs, set the subdivisionScheme to 'catmullClark'."
But how can I tagged as subdivs ?
Capture d'écran 2024-08-28 130248.png (1016.4 KB)
Capture d'écran 2024-08-28 130806.png (1019.2 KB)
I'm just wondering, what is the advantage of this approach over immediately doing a subdivide in SOP?
philippepetitpas
Hmm it seems the way the componentbuilder HDA is constructed makes it hard to have a mix of subdiv and mesh geometry. The good news is that the component builder is just an HDA using a sopimport, so you can unlock and jump in and enable "USD Custom Attributes" on node "base_geo" and it should work. The other limitation I spotted is that the component builders internal sop network overrides the __subdiv__ primitive group, which is the other mechanism sopimport uses to determine which faces do/don't get catmullclark subdivision.
RGaal
A subdivide sop just applies one or more iterations of subdivision to a polygon mesh. In the end you will still have a polygon mesh though, which is now heavier and still may not be smooth enough depending on camera angle etc.
A subdivision surface on the other hand is perfectly smooth, kind of like if an infinite number of subdivision iterations had been applied. Given a subdivision surface at render time, Karma figures out how many polygons to use to approximate the surface smoothly based on the camera position/angle. Every face will get diced into small pixel-size micro-polygons based on its size on screen and so always look perfectly smooth.
Another advantage of subdivision surfaces is you don't need to generate normals - subdivision surfaces generate perfectly correct and smooth normals automatically.
Edited by antc - Aug. 29, 2024 10:10:19
Yeah Component Builder is intentionally simple/broad. Usually what I've seen is people do when they need mixed subdivs/meshes, is to append an Edit Mesh LOP [www.sidefx.com] after Component Geometry, to mark their subdivs. In the Scene Graph Tree, if you RMB on meshes, you can select Edit Primitive with New Node, which will create a Mesh LOP in edit mode.
You could also set osd_schemeSOP Attribute to define which parts are subdivs. We'd like to make this easier in a future release, but see this doc here for more info about the prim attributes: https://www.sidefx.com/docs/houdini/solaris/sop_import.html#subd [www.sidefx.com]
I'm o.d.d.
Thank you all for the moment I use the « edit mesh » solution
