Hello Houdini Community,
I'm a beginner. Would anyone be able to let me know how I can procedurally add a polygon face to each side of the deformed box in the attached file?
How to add polygons faces between curves?
382 2 0- KETHRO
- 2 posts
- Mike_A
- 255 posts
File attached with a couple of simple alternatives.
This is trickier than you might think. How would H know how to build the polygons? Ie, which points to connect in what order?
The polygon elements of H are set up differently to other 3D softwares - so It is a wise investment of your time to learn and understand the difference between points and vertices (two different things in H), edges, and polygons.
Here's a starter:
https://tokeru.com/cgwiki/Points_and_Verts_and_Prims.html [tokeru.com]
If you are bringing in an iges file... H has (sadly) very poor facilities. I'm not sure what iges version it supports.
Here's a starter:
Edited by Mike_A - Sept. 16, 2024 17:26:26
- KETHRO
- 2 posts
