Karma XPU - MaterialX carpaint?
   751   3   3
Hi guys,
um could someone point me in the right direction. I'm trying to work out if you can make a carpaint shader with those reflective flakes using only materialX for Karma XPU? Anyone got a solution to this? Thanks.
Hope this is helpful!
Edited by goldleaf - Oct. 18, 2024 14:09:12
UsdMaterialX_CarPaintFlakes_Example.zip (10.9 MB)
I'm o.d.d.
Wow, that is exactly what I was trying to do. Thank you so much!
thanks a lot for this clever setup !
I have a quick question regarding the normal setup. The seeds (setupseed3 and setupseed4) used to randomize the red and green channels of the normal map are currently identical (seed = 11).
Was this intentional, or would it be better to assign a different seed for each channel?
Thanks !
