As far as I can see there is no built-in HScript variable for 'current date'. What would be the best option to add that to a ROP file name output on a Windows system?
I find it helpful to have a date + time variable when creating test renders.
How to add the current date to file name output?
422 4 2- Mike_A
- 269 posts
- Artificial Kid
- 2 posts
I guess the easiest way is by python. Anyway you could find something useful in this topic [www.sidefx.com]
- sanjeevmansotra
- 2 posts
Hello my name is Sanjeev Mansotra from India.
To add the current date to a file name in a ROP file output on a Windows system, you can use Python expressions within Houdini since there’s no direct HScript variable for the current date. In the file name field, use this expression:
`pythonexprs("import datetime; datetime.datetime.now().strftime('%Y-%m-%d')")`
This will insert the current date in YYYY-MM-DD format, or adjust the date format within strftime() as needed. This approach is flexible and works well for dynamic date-stamping in output file names.
Edited by sanjeevmansotra - Oct. 29, 2024 07:43:15
- WowNems
- 43 posts
- toadstorm
- 377 posts
I posted a snippet in the linked thread that works, try this:
Hscript doesn't seem to want to evaluate line breaks as Python sees them, so this is an alternative syntax you can use. If it's too ugly for you, create a spare string parm and set the expression to:
Then channel reference that in your filename expression using `chs("myParm")`
$HIP/render/$HIPNAME.$OS.`pythonexprs("str(__import__('datetime').datetime.now().strftime('%Y%m%d_%H%M%S'))")`.$F4.exr
import datetime return datetime.datetime.now().strftime('%Y%m%d_%H%M%S')
