Channel reference works in reverse?
   Views 624   Replies 5   Subscribers 1
Something that always threw me off.
1. I use a channel reference on parameter "x" to get its value from another parameter which I will call the "source".
2. changing the source value will update parameter "x"'s value. This is obviously expected.
3. changing the value on parameter "x" will update the value on the source parameter????
How is that possible? There is no expression on the source parameter, so what is causing the value to change?
Thanks,
Evan
If you don't want the reverse connection/behaviour,
after making the reference, just right click on the parameter and select lock parameter.
BabaJ
Thanks. I was more so wondering why it happens.
Edited by evanrudefx - Jan. 13, 2025 18:19:18
Thanks,
Evan
it's for convenience
it is sort of like:
source_parm = my_parm.getReferencedParm()
source_parm.set( new_value )
it only works if you have direct reference without additional expression, also if you open Animation Editor it will show you channel of referenced parameter
it is not as elegant as instanced parameters in MAX for example, but I'm glad it's at least working like this
Edited by tamte - Jan. 13, 2025 20:56:38
tamte
it is sort of like:
Thanks,
that is interesting, if I do the channel reference and add + 0 or something additional like you said then it doesn't work in reverse.
Thanks,
Evan
evanrudefx
that's because it may be impossible to reverse the expression in general, so to me it just makes sense that this is limited to direct channel references as that makes it clear that it is sort of an "instance" of the source parameter
