Is it possible to have a repeating texture on a line, using mantra line rendering?
Cant seem to put proper UV coordinates since a line is just one point large, the texture gets stretched in the width.
Thanks a lot.
Line texturing ?
6309 7 2- vinz
- 113 posts
- Wish
- 282 posts
- vinz
- 113 posts
- buki
- 1769 posts
hi!
try to scale the U value at the range attributes
- Wish
- 282 posts
- vinz
- 113 posts
I've tried your suggestions, but I don't think it can works with tweaking the uv coordinates. Here's a picture showing the problem. On the left is a nurbs grid (0.5*2) with uvtexture set to rows and columns and the y scale is 4. On the right is the line (length = 2, attribute width set to 0.5).
The uvs for the grid are 0,1,0,1,0,1… wich correspond to the left and right point of the grid for uv and go from 0 to 4 for uv.
for the line, it's just 0,0,0,0.. for uv since there are no left and right points.
So I was wondering if something can be done about this.
Thanks again.
Thanks again.
- symek
- 1390 posts
- vinz
- 113 posts
