Im doing a server in python but I'm not familiar with python under Houdini. Can I get all nodes from houdini and its type.
Im doing a statistical report of houdini scenes.
thanks,
Alexis
Python command to list all nodes in houdini?
19889 8 1- abahena
- 33 posts
- graham
- 1909 posts
- edward
- 7760 posts
- paul_winex
- 1 posts
- Alex3dac
- 1 posts
- bonsak
- 459 posts
- goldleaf
- 4177 posts
You can also list all of the node types from a version of Houdini with this command:
If you run that from two different versions of hython, you can diff the results. For example, this compares 16.5.323 and 16.5.473:
And if you need to, you can add this flag to get all of the parameters and values, and diff those too:
The version of hython being run is was really matters; you'll need to run the hython in each version of Houdini you wish to print out the list for.
Hope that helps!
hython $HFS/houdini/python2.7libs/opnode_sum.py > all_nodes.txt
hython $HFS/houdini/python2.7libs/opnode_sum.py -p > all_nodes_and_parms.txt
Hope that helps!
Edited by goldleaf - July 14, 2018 23:48:33
I'm o.d.d.
- mjdynamic
- 3 posts
- Cicuta
- 61 posts
Hi!
I am using a parser method that seems pretty neat in case you only want a more controlled search: https://www.sidefx.com/docs/houdini/hom/nodesearch.html [www.sidefx.com]
In terms of performance, to my understanding this looks faster than children() or allSubChildren() but perhaps someone can confirm that (?)
Edited by Cicuta - Jan. 30, 2024 16:37:11
