Objects won't show up
2629 10 2- mosberlin
- 9 posts
Hi!
I am using Houdini 16.0.557 with Windows 10. At the moment, when I create a Object, no Objects is shown. When I use the selection tool, I can see that there is a object, but its not shown. I already reinstalled it. Deleted the files in the document folder and reinstalled it.
I am using thinkpad x230
Does anybody knows why this is happening?
- malbrecht
- 806 posts
Moin,
just to be sure: By “create an object” you mean “click on box/sphere/whatever” and then PLACE IT in the viewport, i.e. CLICKING in the viewport where you want the object to appear? Or are you using “create default object” (which should appear at the origin)?
Have you tried holding space and pressing “h” (for “Home”), to be sure that your virtual camera isn't off?
Marc
Marc
Good bye.
Good bye.
- mosberlin
- 9 posts
- malbrecht
- 806 posts
Those? Should not be a problem …
Good bye.
Good bye.
- mosberlin
- 9 posts
This option does not show anything when I enable it (the reference plane option).
Here are two screenshots. [imgur.com]
Edited by mosberlin - March 29, 2017 16:09:22
- malbrecht
- 806 posts
hmm … hang on, your screenshots do not show what you described in your first comment :-)
You have a “remesh” with a WARNING hooked after the sphere. You need to check what the warning is about first before seeking the problem elsewhere, I guess.
What happens if you set the visibility flag (blue button right most) on the sphere node instead of the remesh node? Have you, maybe, used the “wrong” primitive type for the sphere so that it cannot be remeshed?
Marc
Marc
Good bye.
Good bye.
- mosberlin
- 9 posts
I uploaded the second screenshot as well. The only difference between the screenshots is the enabled option of the reference plane.
I already tried this with different objects. Like Sphere, geometry, etc. Also the construction plane is not shown when the option is enabled.
(the warning on the remesh says that the geometry has been changed to triangles and quads)
- malbrecht
- 806 posts
Can you upload the scene, please? I guess we are crosstalking here
Good bye.
Good bye.
- mosberlin
- 9 posts
- anon_user_37409885
- 4189 posts
- mosberlin
- 9 posts
