Hi!
when I have two attributes coming from different channel and I want to connect them in a Point Wrangler, why does the Point Wrangler does not get the attributes from the second channel automatically?
I uploaded a picture to show, what I exactly mean.
In my case: I created an attribute in the Point Wrangler Node “set Vorticity” and in the node "merging the channels I want to use it without using the command point(.., …,… )
Thanks for your help !
attributes from different channels
2110 3 1- mosberlin
- 9 posts
- malbrecht
- 806 posts
Moin,
use “pointattrib(1,…)” to retrieve the attributes from your second input.
Marc
Marc
Good bye.
Good bye.
- tamte
- 8622 posts
what do you mean automatically?
if you want to get attrib of matching point (by @ptnum or some attrib like @id) of other inputs
you can use type@opinput1_attribname to get the attribute of desired type from second (or any) input
like if your vorticity attrib is float length of vorticity
etc…
f@vorticity += f@opinput1_vorticity; // to add vortocity attrib of first and second input together
f@vorticity = max(f@vorticity, f@opinput1_vorticity); // to get maximum value of vortocity attrib
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- mosberlin
- 9 posts
