I created an HDA myCam. And need to do something in python for Object/cam and myCam.
Though I can test if the type.name() is “myCam”. I want a more general method to know if the node belongs to camera.
Are there any way to know if a node is a camera (include cam HDA)?
How to know if a node is camera (include cam HDA) ?
2508 7 3- jerry7
- 628 posts
- malbrecht
- 806 posts
have you tried reading the documentation? Node type for “cam” is … wait for it … “cam” :-)
Documentation says “node.type()” gives you the node type, so in Python you would do something like, which would return “cam”. You could traverse all your “/obj” nodes and check for each node's type whether it is “cam”.
Marc
hou.node("/obj/myCam").type()
Marc
Good bye.
Good bye.
- Jonathan de Blok
- 256 posts
malbrecht
Documentation says “node.type()” gives you the node type, so in Python you would do something like, which would return “cam”. You could traverse all your “/obj” nodes and check for each node's type whether it is “cam”.hou.node("/obj/myCam").type()
Marc
…type().name() would be the thing that returns the actual name string, important since you want to be able to compare it to the string “cam”
More code, less clicks.
- jsmack
- 7812 posts
Jonathan de Blokmalbrecht
Marc
That only works for the houdini cam. The OP is asking how to tell if any node is a camera class, not type. I'm not sure if there is a way other than recursive glob, which isn't very friendly for simple masking. I've resorted to hard coded lists of type names for this purpose.
- doctorbob
- 30 posts
hey all,
as a followup to this, i trawled through the HTOA properties source and discovered they were using the node.type().definition().extraInfo() thingo - it has a “subtype=cam” entry for camera derived types.
It certainly works for my own custom camera OTLs.
i have no idea whether this is a formal houdini thing that you can 100% rely upon, but as hou has no concept of type def subclasses, it's the closest that i've ever seen (short of globbing parms and saying “yep, this looks like a camera… ish”)
hope this helps.
cheers,
chrisg
hope this helps.
cheers,
chrisg
- jsmack
- 7812 posts
doctorbob
It doesn't work on non-otl cameras though, since their types don't have a ‘definition’, such as the built in ‘cam’ type and lopimportcamera type.
Using
mycam in mycam.parent().recursiveGlob(mycam.name(), filter=hou.nodeTypeFilter.ObjCamera)
- doctorbob
- 30 posts
- elovikov
- 122 posts
Hi all!
Looks like these classes are not exposed to HOM. As a workaround you can use inlinecpp to check if OBJ node is a camera. Though you need Visual Studio installed (or Xcode on OSX) to use it. So no simple way afaik
Try to put this in session module:
Then you can check OBJ nodes like this
That would work with builtin and hda cameras
import inlinecpp utils = inlinecpp.createLibrary("utils", includes="#include <OBJ/OBJ_Node.h>", function_sources=[""" bool isCamera(OBJ_Node* node) { return node->castToOBJCamera() != NULL; } """])
node = hou.node("obj/cam1/") geo_node = hou.node("obj/geo1/") print hou.session.utils.isCamera(node) # True print hou.session.utils.isCamera(geo_node) # False
Edited by elovikov - Aug. 18, 2020 18:40:14
